a] Is it possible to show the articles as groups? So instead of NiceMovie.r00....NiceMovie.r88 just one grouped icon NiceMove (expand by click the +)
b] Is it possible to filter the articles? That very useful for locating a download I want to move up in the queue.
Task manager - Articles window
Code: Select all
Client: Usenet Explorer v4.9.3 - 64 bit (registered)
OS: Window 7 Ultimate - 64 bit
Anti Virus: Avast Premium - 64 bit (updated daily)
Firewall: Avast Premium - 64 bit (updated daily)
Usenet: Eweka
Re: Task manager - Articles window
The task manager window is optimized for speed, I didn't add collections there.
You can use edit menu->queued, then e.g. context menu, advanced->download immediately or download with priority, no need to reenter the save folder.
Also in the task manager you can try context menu, "Select related headers" Alt+S, then drag the headers to the desired position or invoke "Set priority".
I know/knew that Alex. I use that functionality.alex wrote:You can use edit menu->queued, then e.g. context menu, advanced->download immediately or download with priority, no need to reenter the save folder.
Let me clarify my 'problem'.
Assume a download queue with 100 download sets in it.
Ech set containing 50 RARs on average. That's a list of 500 items.
Then it can be time consuming to find a certain download that I want to move to the top of the queue.
So it's not about how to priortize but how to locate the download.
I hop ethat explains it better.
Code: Select all
Usenet: Eweka
