Normally when i use the quick filter while displaying a newsgroup headers, all headers are temporally hidden except the ones that match the filter, deleted included when enabled;
By working by remote desktop i did something, but i don't know what, maybe a keyboard sequence.
Now when applying a quick filter, the unmatched header are still visibile, the matching headers has a yellow mark on the left and the matching deleted headers does never show with any setting; after a week i cannot figure what setting is and i made i backup that include this situation so no rollback option unless reinstall...
Anyone can help?
At the moment i'm using the search function for the deleted headers.
quick filter behaviour changed, how to turn it back?
Re: quick filter behaviour changed, how to turn it back?
Is the quick filter bar rightmost check box (to the right of the "Clear" button) checked?
It turns the quick filter into "Find" filter.
Just uncheck the check box then.
Was unchecked, i checked it and the problem was the same, then i unchecked it and now the issue is gone!!!
I have screenshots jpegs of all settings and i didn't touch anything that was like in the pictures, i only tried settings and menu that wasn't included in screenshots because they're from a older UE version, so i didn't even bother to know what that checkbox do or tried it (also many other settings are still alien to me).
Thank for your support.
