saved passwords
saved passwords
where can I save or input a password for a password protected download? (that it automatic unpack)
Re: saved passwords
just use context menu -> set unrar password
it can be rar itself, par2 or split set associated with the rar file, as to the latter when the rar is verified or joined respectively UE will apply the par2/split set associated unrar password to the rar file.
Re: saved passwords
cant find "set unrar password" !?
Re: saved passwords
tasks menu->task manager, in the "Unpack" tab, press the right mouse button to see the context menu, you should see the "Set unrar password" menu entry, second entry from the bottom just above "Properties"?
Re: saved passwords
have send you an email...
