I reinstalled windows and UE.
I still have all the setting on a backup.
How do I restore them?
Import settings
Import settings
Code: Select all
Client: Usenet Explorer v4.9.3 - 64 bit (registered)
OS: Window 7 Ultimate - 64 bit
Anti Virus: Avast Premium - 64 bit (updated daily)
Firewall: Avast Premium - 64 bit (updated daily)
Usenet: Eweka
Re: Import settings
Found part of the solution. Store where the datbase is. But where is that?
(installed in default location)
Code: Select all
Usenet: Eweka
Re: Import settings
UE Asks where to put the database the fist time you run it. And you can change/view the location in "Properties->General->Database".
jonib
jonib
Get Usenet Explorer Automatic Updater here. You want to flatter me?
Re: Import settings
Thanks jonib.
One last problem remaining.
Every time I start a download by opening an .nzb UE asks where to store the download.
I've set a default dir in Save/Unpack but still it asks every time if the directory is correct.
Code: Select all
Usenet: Eweka
Re: Import settings
Do you have "Auto - folder out of nzb name" checked in "Properties->Search/Import->NZB files"?Terry wrote:Every time I start a download by opening an .nzb UE asks where to store the download.
jonib
