I messed up the layout how to re-arrange the Workspace
jd
Post by jd »
I somehow messed up the layout. I can't re-arrannge and resize the Workspace and TaskManager etc as I like them. Heeeelp. Already played arround with docking, framed etc options
:mrgreen: .
Re: I messed up the layout how to re-arrange the Workspace
do you have docking task manager/workspace options in the view menu checked and it doesn't help?
exit UE, in the UE database Settings directory try to delete all api.* files then restart it, let me know if it worked.
jd
Post by jd »
Perfect! Now everything is back to normal! Thanks Alex.
