search is searching but not finding
Eagle1
Post by Eagle1 »
Hello,
Early in the afternoon, I searched and downloaded fine.
Then, few minutes ago, I'm searching but the search doesn't find anything at all, whatever I try. I upgraded to 4.6 but no more success. I tried to reset search configurations and no more success...
It's happen on my two computers. To my knowledge, my internet access did not change during that time ( I mean firewall / proxy).
Is this general or just me ? What can I do ?
Re: search is searching but not finding
does the search fail or it returns no matches found?
if no matches found maybe you accidentally changed search settings
edit menu->properties->search/import e.g. if you change from "all words" to "boolean wildmat match" it will return different results.
or give me here or pm an example of such search.
