Hi... just wondering if there is a keep alive features hidden somewhere in newspro (checked all setting on my reg copy but i was not able to find any).
My ISP has a limit on max number of connections i can made in 1 hour... so I wish to know if i can set this somewhere in newspro or simply say to open 1 or more connections and use the keep alive.... if any
Connections Keep Alive
The option is in properties->general, keep-alive, it is checked by default since it works faster.
If a connection is not active for 10-15 minutes - usually it is closed from the server side, also if you cancelled tasks in the middle - the connecton has to be closed, but in general keep-alive will reduce the number of connection estabilshments significantly.
