Here is a program that will search http://alt.binaries.nl and let you export message IDs to an NZB file which you can import into NewsPro.
http://used.hellhound.nl/EvolutionSearch.rar
newsgroup search program with NZB support
I did have a problem with queing up 10 or so files and then exporting to a nzb file. For some reason, it only captured the first few files and then repeated the last file over and over.
Here is a portion of the nzb file, when the issue happened:
<file subject="1998-11-20 Baseball Mogul 99 Final-CLS "BB99FINL.C03" (1/4)" date="1074956880" poster="Amous">
<groups>
<group>alt.binaries.warez.win95-games</group>
</groups>
<segments>
<segment bytes="746728" number="1">95CdnaAZXqqX54_dRVn2sQ@giganews.com</segment>
<segment bytes="746728" number="2">95CdnaMZXqq554_dRVn2sQ@giganews.com</segment>
<segment bytes="746728" number="3">95CdnaIZXqqg54_dRVn2sQ@giganews.com</segment>
<segment bytes="746728" number="4">95Cdnd0ZXqrL54_dRVn2sQ@giganews.com</segment>
</segments>
</file>
<file subject="1998-11-20 Baseball Mogul 99 Final-CLS "BB99FINL.C04" (1/4)" date="1074958560" poster="Amous">
<groups>
</groups>
<segments>
<segment bytes="746624" number="1">95CdndwZXqrF54_dRVn2sQ@giganews.com</segment>
<segment bytes="746624" number="2">95Cdnd8ZXqrs54_dRVn2sQ@giganews.com</segment>
<segment bytes="746624" number="3">95Cdnd4ZXqoW54_dRVn2sQ@giganews.com</segment>
<segment bytes="746624" number="4">95CdndkZXqo554_dRVn2sQ@giganews.com</segment>
</segments>
</file>
<groups>
</groups>
<segments>
</segments>
</file>
<groups>
</groups>
<segments>
</segments>
</file>
<groups>
</groups>
<segments>
</segments>
</file>
<groups>
</groups>
<segments>
</segments>
</file>
thanks, but it didn't work here...
but you inspired me to create my own version
i don't know if it always works but til now it worked
it very primitif and programmed in visual basic but it does the trick
i read the results and put it in a table and you can simply select the files you want and tell the program to get the nzb files associated with it
hope someone will try it and like it...
it can be downloaded here:
http://home.student.utwente.nl/s.h.tenh ... b_abnl.zip
the is also an installer if the program doesn't work here:
http://home.student.utwente.nl/s.h.tenh ... nstall.zip
it's very simple and programmed in visual basic but it does the trick
Version 0.24B of evolutionsearch is now available for download here:
http://www.kapfrank.nl/software/EvolutionSearch.rar
I an NOT the maker of this fine tool, I just provide a link
