Please help. After a windows restart I can not see newspro anymore.
I enter newspro.exe and newspro is only starting in the taskbar but not on the desktop.
I have re-installed but it was the same.
newspro is not starting
i don't understand exactly what you mean so i give several solutions:
press the taskbar icon and uncheck edit menu->start minimized
there should be either icon on the task bar or icon in the system tray.
the 'worst case': if newspro doesn't appear and you see it only in the system tray (newspro window is somewhere beyond the screen) - uncheck 'system tray' in the context menu so it will be in the task bar, then choose 'maximize from the context menu. you shuld see newspro then, then invoke view menu->normalize.
Stop downloading stuff from that user then
And be happy your scanner works.....
- Contact:
- Contact:
it is most likely an scr file, which is a screen saver. It is an executable file so if you run it it would infect the machine (assuming no AV software is installed). I highly doubt it was a picture that was infected. What was the exact post? My guess is the attachment was something like this:
someCelebrity.jpg.scr
You would get it in the downloaded file if NAV didnt clean the npr file as well.
this crap happens all the time in picture groups. Search for .scr and see how many they are. Download a few and I bet they are ALL infected.
Mike Stammer
