Search Failed
n2mdk
Search Failed
Post by n2mdk »
Getting a Search Failed Search service configuration is inconsistent. Try a bit later maybe server rearrangement is in progress.
Re: Search Failed
I'm fixing this, problem with one server local ip address, I'll handle it somehow shortly.
n2mdk
Re: Search Failed
Post by n2mdk »
Thanks Alex I see it's working again.
Great Work and Great Support.
