I'll restart it in backup again. I will try to have DIMMs resettles, I think the problem is memory electrical contact. In any case I'm trying to replace the server, if all goes as planned this one will be out of service and there will be more retention.
RAM has been reinserted, we'll see if it will happen again.
It is 4th time it shuts down suddenly, just first two times I was alerted fast. It happened on average with 4 day interval, the last time it was 1 day. If it lasts now for more than a week without restarting the issue is most likely fixed.
Update after a while: the issue didn't resurface again.
