Unrar many posts with the same password
jd
Post by jd »
I scheduled over a 100 posts to download that all use the same RAR password. I have to right click each one and commit the password. Would be great if you could select the posts with the mouse and make it use the same PW for the selection.
Re: Unrar many posts with the same password
I checked the code, currently the function applies to the focused item only.
I can change it to selection.
jd
Post by jd »
Great and probably easy to implement? :D
Actually there was a reason why it is just one entry.
I added selection to the code, I will likely recheck and compile tomorrow, along with fixing the collection size bug in search views.
I've added it in v4.9.3, check if all works.
jd
Post by jd »
Sorry for late late reply, but of course it works perfectly!
