Saved queue suspended ....?
dxcarnadi
Post by dxcarnadi »
Hallo
I got an error message .. (see attachment).
What does it mean?
What should I do?
Thank you.
Saved queue suspended 2016-03-29 11_01_21-Usenet Explorer.jpg (7.2 KiB) Viewed 7141 times
Re: Saved queue suspended ....?
It could be the file has been opened by another process (e.g. you overwrite another file, but it is opened by antivirus, unrar or editor etc.) or the save folder is read only (folder access permissions).
You can change the save destination of the topmost item in task manager->save, right click the topmost entry and invoke "save path", or you can select all affected entries the folder is not writable (or then you can try to change the access permissions of the folder).
After done, just unsuspend the save queue and UE will try to save again.
