Various things
Glamdring
Various things
Post by Glamdring »
Dear Alex,
With 4.9.6 (64 bit) on Windows 10:
In my setup clicking the button 'Delete whole history' doesn't delete Unrar Passwords.
I would like to see an option not to count bandwidth at all.
With Save/Unpack properties section Unrar I would like to see an option to derive name of folder after nzb.
Re: Various things
As of now in workspace, servers pane, the context menu->advanced submenu menu there is reset download limits and bandwidth counters. I see also the reset daily option in edit menu->properties->servers. Is it critical to disable it completely?
I'll check regarding rar passwords, it appears the working by itself "Unrar: Passwords" option at the bottom of the dialog is not engaged when invoking "Delete whole history".
When importing nzb I think it already creates the save directory using the nzb file name.
