search syntax? Colin Dexter <> Dexter Colin ...!?
dxcarnadi
Post by dxcarnadi »
Hello
It seems that one must know the right order of the keywords to search the usenet ... right?
Please see picture.
Or .. is there another syntax if one doesn't care how the order of the words?
Thank you.
2016-08-25 08_24_31-Usenet Explorer - [Search service].jpg (154.67 KiB) Viewed 6155 times
Re: search syntax? Colin Dexter <> Dexter Colin ...!?
Edit menu -> properties -> search/import, search and quick filter bar syntax, options, check "In same order".
Or you can use boolean wildmats for more advanced searches.
