Error 482 Authentication rejected (Server)
dxcarnadi
Post by dxcarnadi »
Please see the next post .. it is a correction of the main post. Thank you.
Hello
Today I tested a new Usenet Server (Free-Usenet) with UE and SABnzbd.
The tests with SABnzbd consists of:
1. test SABnzbd to Server.
2. test a download
Both tests are OK.
The tests with Usenet Explorer are not successful.
First .. I cannot find a key to test/check whether I have entered the right data in UE-properties.
Second .. during a download .. I got this error messages:
What have I done wrong?
Thank you.
PS. SABnzbd displays the Password readable. So I can check it.
dxcarnadi
Re: Error 482 Authentication rejected (Server)
Post by dxcarnadi »
Hello
I've read that Free-Usenet-server can only be used with "SABnzbd".
Can I use UE instead of SABnzbd though .. if I avoid certain actions with UE?
I will not "browse" Free-Usenet-server.
First I consult UE-Search-Server .. then UE "ask" Free-Usenet-server to give the item.
Otherwise I must ask UE to build a NZB-file .. and export the NZB-file on a disk.
Then must SABnzbd read that NZB-file .. and then SABnzbd ask Free-Usenet-server to give the contents of the NZB-file.
I've test these steps with success.
Is that the only way?
Thank you.
dxcarnadi
Post by dxcarnadi »
I entered the wrong username or passwords.
Now no problem
