Deleting unchecked bodies in active window
In an active newsgroup window, is it possible to delete all of the bodies that are *not* checked with a simple command (as opposed to highlighting them all and then hitting DEL)? Or should this be a feature request? It would be very convenient to be able to select what you want to download and then be able to remove everything else in the window with one click.
Re: Deleting unchecked bodies in active window
You can check "bodies" in the quick filter, then it will show only articles with bodies.
But also the bodies can be automatically deleted on save, including those with no attachments, see edit menu->properties->save/unpack, save.
