Search Failed (8)... again
DonM
Post by DonM »
The searches have been really fast for the past few weeks... today, I'm getting no results at all
"Search Failed (8)"
fellowda
I have been unable to connect for several weeks.
Post by fellowda »
System Maintenance, System Problems?????
Re: I have been unable to connect for several hours.
The server ip has changed and I was on the move. It should work now.
DonM
Post by DonM »
alex wrote:The server ip has changed and I was on the move. It should work now.
Thanks Alex :-)
Re: Search Failed (8)... again
Maybe I'll change it so it will automatically fix the configuration in such a case, it is pretty easy.
I cannot use dynamic dns since it didn't work for everyone.
