this works very well. Great feature. I was wondering if it was possible to unpack the RAR file and derive it's name from the NZB file also? I have a neatly named folder, but inside is a "sdfchsadhj23h.mkv" or something. Would be great to have the option.
Unrar to subdir-> From nzb collection name
Re: Unrar to subdir-> From nzb collection name
Do you mean to have an option to do it for all downloads or per download basis?
If the latter the question is how to implement it, since e.g. if when marking for download&save it would double the already numerous download&save options.
You basically have the option already. "Unrar to subdir" then relative folder, Derive Name.
Maybe a checkbox "derive name of unpacked file from NZB file".
If it is possible.
If it is possible.
- Snap1.png (23.05 KiB) Viewed 10856 times
I'll check it out, I'll pm you if there is a test version. Actually it would need another combo box.
http://www.usenetexplorer.com/temp/ue553b.rar
There is now another combo box under the combo box in your screenshot.
Check if it works as expected, it looks like working.
It simply renames, if there are more than one file with the same extension, rename will just fail and the original file name will be preserved.
Also you don't have to create relative folder per download as there are two combo boxes one for folder and one for files.
Works perfectly so far! Very, very good, thanks!
