Search failed (5) Too many users
cthulhiac
Post by cthulhiac »
Is this due to a DoS attack or is there a limit to the number of users? First time I've seen it.
Re: Search failed (5) Too many users
i noticed, checking it, it could be it ran out of memory after running for months, restarting it now.
Looks like it is running ok after reboot.
Update:
It happened second time after 4 days, while I was monitoring the server with very similar picture.
Given the timing it could be because of recently exposed Windows RDP vulnerability, which I have now patched manually.
https://portal.msrc.microsoft.com/en-US ... -2019-0708
There is some "research" exploit code available, maybe enough to make the system unstable, but without yet taking full control.
The affected server uses the standard RDP port, so only it was hit.
If it won't happen again this was the cause.
