Last few days there was an issue with one server which caused me to switch to backup configurations with limited retention and short downtimes.
It happened first around August 1, then second time on September 4, then starting October 29 it got worse.
It was now narrowed to corrupted router settings, so the problem is likely to be solved soon.
Update: the problem was solved by resetting the router to factory settings
Router issue
