So I got a lot of downloads lately that didn't indicate a password and wouldn't unRAR.
Turns out the password is INSIDE the NZB.
It's apparently a long common feature of NZB's but rarely used, until recently.
The NZB looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE nzb PUBLIC "-//newzBin//DTD NZB 1.1//EN" "http://www.newzbin.com/DTD/nzb/nzb-1.1.dtd">
<nzb xmlns="http://www.newzbin.com/DTD/2003/nzb">
<head>
<meta type="password">in23ZLB2fr6sD96cH00VYT5mJZDvmMGG</meta>
</head>
<file poster="FRIENDS" date="1590578949" subject="[1/61] - "S2AR3a1HQIFPuJJrQAd6A5fk2QYlcaqZ.7z.001" yEnc 52428800 (1/37)">
<groups>
<group>alt.binaries.friends</group>
</groups>
<segments>
<segment bytes="1479351" number="1">HbOzVlLpHzDdHdIeCvTyPdJq-1590578949315@nyuu</segment>
<segment bytes="1479075" number="2">PtHuTaRbKiMtXgEpPpWlPaYm-1590578949322@nyuu</segment>
<segment bytes="1479020" number="3">FbGjWcKrPlRxQoWzIoSoRkCu-1590578949331@nyuu</segment>
<segment bytes="1479177" number="4">IpFhQcJhByQhZwMfDeYxBoKi-1590578949346@nyuu</segment>
<segment bytes="1479143" number="5">ZoGeDsAuKgNjWhUvUkSmHbRr-1590578949358@nyuu</segment>
<segment bytes="1478995" number="6">JjXyUqHaDcJrQrYmByKhOwRu-1590578949364@nyuu</segment>
<segment bytes="1478933" number="7">JyKaZaKoHkQkKoAlJaAlXnEw-1590578949368@nyuu</segment>
<segment bytes="1479106" number="8">PiSsEuAbVaXrOpFkMsGuBiXm-1590578949373@nyuu</segment>
<segment bytes="1479137" number="9">AxAgHhAzFpCpQhJpOqMaUiUn-1590578949377@nyuu</segment>
<segment bytes="1479192" number="10">UmJaOlUuWdZpMuKkRvPbSfDu-1590578949406@nyuu</segment>
<segment bytes="1479173" number="11">FcHrFbUhGkYzGxMlFzVgPwXq-1590578949408@nyuu</segment>
<segment bytes="1478923" number="12">UiEmAgNhJmNsCaGpWrBpViBx-1590578949416@nyuu</segment>
The segments go on of course.
The password is on the 5th line.
SAB-NZB can read this and unRAR, but UE cannot.
So it's not only a feature request but if these things become more common it will be a flat out necessity!
It does explain other RAR's that were passworded and had to be thrown away...
NZB's now have passwords inside them...
Re: NZB's now have passwords inside them...
The functionality is already there, just make sure you have "Import as collection" checked (it is checked by default) in edit menu->properties->search/import, import options, since the password is added to the collection name.
