Another new obfuscation method for unpacked files?
jd
Post by jd »
After unpack I get the files separated in a correctly named folder.
But the MKV inside has a cryptic name. Any chance to force name the unpacked files to the name of the NZB? Example attached.
Bridgerton.S02E01.1080p.NF.WEB-DL.DDPA5.1.x264-TEPES-4P.zip
(20.04 KiB) Downloaded 448 times
Re: Another new obfuscation method for unpacked files?
It is just file named like that, if to have an option to rename files after the nzb file it is not clear if it will be useful for all cases, the question is when to rename and not to rename.
jd
Post by jd »
Maybe the rename option can be enforced. In Save/Unpack "Derive from nzb collection name" so it always names the output what the NZBs name is?
Just an idea.
