Hi. Search stopped working for me today with "Search failed (8)" message. After a few tries it said something about trying to retrieve configuration, but still didn't work. Tried resetting search configuration in settings, but that didn't help. UE reaches out to the web site IP after the reset then to various ports on 47.197.50.146 then 73.187.26.100 and then errors out again.
