xpost?
tomhock
xpost?
Post by tomhock »
I've been running into nzb files with the term "xpost" at the end. UE processes and saves some of these sucessfully, but others fail. Apparently, some of them aren't rar sets but complete files, but most contain several independent files. UE downloads the segments, but they all have random-looking filenames without extensions. UE doesn't know how to check, rename, or unrar these sets.
I've attached a zip with an example nzb file.
xpost-example.zip
(86.42 KiB) Downloaded 311 times
Re: xpost?
I'll check it out if it is something new.
Re: xpost?
it appears par2 files don't have extension.
Re: xpost?
It took some time, as I was handling the server side.
You can download the version which handles this here:
http://www.usenetexplorer.com/temp/ue582i.rar
The option edit menu->articles->handle known obfuscated downloads should be checked, it is the default.
If you encounter this again let me know.
