Download and Save immediately with password?
TheWEF
Post by TheWEF »
Here is how I use UE (let me know if I am doing it wrong):
1 Search
2 Select Search result and "Download and Save immediately" (using my shortcut F9)
3 Open "Import"
4 Select the download, rightclick "Set Unrar Password".
5 Enter Password
It would be so much better if I could:
1 Search
2 Select Search result and "Download and Save immediately with password" (using my shortcut F9)
3 Enter Password
Is there a way to do this?
WEF.
Re: Download and Save immediately with password?
Judging by the post date it was a gap in my availability, just noticed the post without replies.
Is it still relevant?
There is an option in edit menu->properties->detect passworded rar files, if to uncheck it the download will continue (so it won't stop with the first part) and only unrar will fail, so there will be a lot of time to set the password.
Sometimes passwords were included in the nzb name and could be automatically retrieved, not sure what is the situation currently.
With so many download&save options it would be maybe awkward to double them by adding a password option for every one of them and also making it to ask to enter password every time by adding an option in properties wouldn't bear well too maybe.
If something definite you can try to reply until the end of July.
