Unable to export to NZB file after key renewal
robbie47
Post by robbie47 »
Hello,
After renewal of my registration key, I can perform search fine as always, but when I want to export a finding to an NZB file I can a error message telling me that I need to renew my key. Exporting to NZB is blocked.
Anyone with a similar problem and a solution for this?
UsenetExplorer version I use is the latest 5.8.2.
Thanks,
Rob
Re: Unable to export to NZB file after key renewal
As email changed, maybe it is still the old key active, try to reenter the latest key, it works fine here.
robbie47
Post by robbie47 »
The problem is resolved.
My name was changed corresponding the new key.
I wasn't aware the name was changed so I only updated the new provided key.
By updating both it was OK.
The name is not used and can be any, just there is a name checksum in the key, so if to enter not the same name a registration error message box will result.
