Filters - need help
olav
Filters - need help
Post by olav »
How can I filter away all posts like
o0103xsb030zyyo36f2l963k9
fa01c6876b55165543bd6edd
Periodically newsgroups are filled with similar posts.
I have tried with some filters like
[0-9a-zA-Z]{15}
[9-8a0z]{15}
without success
tia
They ain't making bugs like Bunny anymore
Re: Filters - need help
Are those posts around 5 years old with .par2 and .rar files?
Subject: fa01c6876b55165543bd6edd [23/32] - "fa01c6876b55165543bd6edd.sfv" yEnc (1/1)
Newsgroups: alt.binaries.flowed,alt.binaries.swedish,alt.binaries.jph
Then maybe to try
* [{0-9}*/*] - \"*
if it will select messages close enough to purge them manually.
If the posts are crossposted to certain newsgroups even if you are not subscribed to them you can try to use the custom section of wildmats.txt in the UE database settings directory in addition to the filter above to reliably filter out future messages, for example for the post above:
1sn<tab>* [{0-9}*/*] - \"*<tab>alt.binaries.flowed,alt.binaries.swedish,alt.binaries.jph
1 is the filter type (always 1), s means subject, n means newsgroups,<tab> means the tab character.
If something is not clear just ask with a concrete example. The functionality was transferred from the server filter and the situation is rather volatile, so there is no robust documentation.
