Slow startup
Grandpakewl
Slow startup
Post by Grandpakewl »
When I start the program, it goes thru a process of "loading tasks" which can take some time. If I have nothing outstanding, that I know of, how do I reduce that part of the startup?
Re: Slow startup
Sorry for the late reply, I didn't look at this forum section.
Check if you see a lot of files in edit menu->bodies, if you purge or delete what is not needed it should start faster then.
I don't remember exactly, maybe it should state it is loading bodies when it happens, if no tasks, loading tasks won't take time.
