Anyone seeing seacrh bring back thousands of results no matter what subject is entered? Pop in 'jethro' for 2 days .. 22k results of all kinds of things..pop in 'south' .. 22k...'aaadfadw' 22k .. seems like it not even matching anything really..
ap
Search brings back same results for anything?
Re: Search brings back same results for anything?
Thanks for noticing that, I was running an updated server version to check it with the next release.
I've restarted the previous server version, the newer one was only running for a few hours.
Later: I've restarted everything again with the updated code, the only problem was if there were no results it inadvertently continued to the added functionality code which is supposed to return many indiscriminate results, so now all should work as intended.
Thanks Alex! Looks good!
ap
ap
