Hello,
using NP 3.75, WinXPpro sp2, and nzb filed
How do I re-import and re-download already retrieved headers and bodies?
I have tried the instructions on previous posts to no avail.
1) UNselect "enable purging deleted headers"
2) reimported the nzb file
3) selected "show deleted headers"
and yet...they do NOT show up.
Is there a way to clear the "already downloaded" list?
thanks,
Michael
nzb: how to re-download already downloaded files?
- Contact:
- Contact:
Using v3.75 should reimported the headers for previous downloaded files.
They're being showed marked "read" (grey).
Are you sure you've got a complete nzb file containing the headers you seek?
It works like a charm on this end.....
Missing Headers
I had a similiar problem , when I accidentally deleted all the headers. They finally showed back up when I went to more, show deleted headers and then undeleted them.
Hope this helps.
Hope this helps.
