minor quirk with visual autosave progress
griffpa
Post by griffpa »
Ive noticed that pressing the escape key to exit viewing a post will close the visual autosave process if its in the middle of a save. These queued files have to be manually saved.
jaapf
Post by jaapf »
Well, dont press [esc] then?
I'm not sure, but I think it only hapens when the autosave-box pop's up after you have started you view of the post.
This means the autosave-box is the active window, so you're [esc] will cancel the autosave....
You will have to focus the program on your post-view to make it active before you can close it with [esc].
Will be easier to just close the view by clicking the cross.....
yes, i know, it is easy to change, until then (the next update) you can make the autosave dialog invisible (in the task manu->autosave->). also it is possible to queue but not to actually save until you remove the block - the option can be found in the same place.
