Hi.
Is there any way to supress cross posts so that I only see the article (binary) once, no matter how many of the groups I'm subscribed to.
Cheers.
Cross Posts
Hello,
I put groups that are similar in a folder to create a virtual group. That way I see the posts only one time. For instance, I put alt.binaries.movies, .svcd, .vcd, (and all similar video groups) into one folder called movies and open the folder. That way I don't miss any posts, but only see them once.
You see it in every newsgroup but for newspro it is the same - if you do something in one newsgroup - it will be reflected everywhere, e.g. you cannot download such messages twice.
so if you marked it for download in one newsgroup, then you closed it and opened another newsgroup containing the same messages you'll see them marked for download.
