First, sorry if my english isn't good enough, i'm from Spain
My problem is that when i'm getting new headers, i can't do anything else with the system....desktop, windows, loading progs, all is very very slow and desesperatelly
While getting headers and open a folder (with newsgroups) to view contents it seems program has crashed but finally, after 5-10-30 minutes it responds and can see the contents of folder. Same for deleting headers. Sometimes to delete 1-2 headers y takes a lots of minutes before responding.
All these problems are only while getting new headers. Also when i click to get new headers for a folder with a several newsgroups, it can be instantly or perhaps it takes a lot of time before responding.
I use WinXP Pro with the latest version of newspro (3.62). Have PIV 1.4Mhz with 256 MB of RAM.
NewsPro Database is on a 80GB Harddrive at 7200rpm. It uses about 30% of processor and 160 MB of ram.
I have 6-8 newservers, and newsgroups are organized by folders, each folder has like 5-8 newsgroups itself.
I recently fixed fld.dat to 200MB and del.dat to 100MB but the same problem goes on.
One solution is reset database, but i don't want to reset database each week / 2 weeks.
I think purge deleted headers will help but not sure. Seems that when getting new header acceses to disk are at 99-100% and don't let me do nothing until it finishes.
Anybody can help me? Tell me some options or parameters/steps that can cause this or follow to get happier
Great program. The Best newsreader.
Thanks in advance
Regards, folgui.
