Changed Computer around, cant find info
ratedr
Post by ratedr »
I moved a bunch of things around on my hard drive including the download, data, temp etc folders in newspro. Now when I open the program..nothing is loaded not the server info I entered, the headers, and the unfinished transfered. How would I load the data, temp stuff that I have already saved back into the program, so it would be like I never moved stuff??
jsdkr
Post by jsdkr »
Put it back the way you found it or go to "file\ switch database and point it to were you moved the files ( in this case things have to be in the right dir. order ) . dat files have to be in the data dir etc. etc. . Or if you have the old files try to overwrite the present files in newspro ??
================== :mrgreen: =====================
look on your hard drive for some database file e.g. "reg.dat" then switch database according to this:
http://www.netwu.com/newspro/phpBB2/viewtopic.php?t=164
it is extremely simple you move or copy database files, run the program and invoke file menu->switch database.
