Search failed: Connection unexpectedly closed by the server
Paddy O'Furniture
Post by Paddy O'Furniture »
I installed the upgrade, Now ,anytime I try to open and get new headers for newsgroups I subscribe to, I get the error message:
Search failed
When I hunt for something using the Search Bar, no connection problem!
What happened?
jonib
Re: Problem After Version 2.8.1 32 Bit Upgrade
Post by jonib »
Paddy O'Furniture wrote:I installed the upgrade, Now ,anytime I try to open and get new headers for newsgroups I subscribe to, I get the error message:
Search failed
What happened?
Maybe some security software on your computer is preventing UE to connect?
jonib
