REQ: NZB output file when using post function in newspro
amfibia
Post by amfibia »
Alex,
Would it be possible to create a nzb file directly from newspro when using the post function.
I know the new powerpost does this, but I prefer newspro to upload to usenet since it has less bugs.
wittenboer
creating nzb file after posting
Post by wittenboer »
i too would like newspro to create a nzb file after posting because powerpost is less stabel than newspro.
i'll consider it when revisiting the posting code, just such code is secondary.
ideally it would be nice to add nzb and par generation and to make a free limited version with only the post code enabled, but it is clearly not the first priority. also maybe when i revisit it the situation on the posting front will be more stable so it will be less work.
nzb file of a post would be very easy to add though.
