change location of the download folder
Mierzoet
Post by Mierzoet »
Hi.
I have moved UE from an old computer to a new computer.
But I now see that the download folder (where the .rar files and .par files are (temporarily) stored, still uses the old path.
I can not seem to find how to change the path to the new location.
The files are stored on the new computer, but still on the c: drive, while I now have UE on the D: drive, and I want the download folder to be on the D drive as well.
Re: change location of the download folder
The download folders are defined in edit menu->properties->newsgroups, e.g. click the "Default" entry, click "browse" to change the default folder.
Unrar folders are set in edit menu->properties->save/unpack, unpack, unrar.
Mierzoet
Post by Mierzoet »
alex wrote:The download folders are defined in edit menu->properties->newsgroups, e.g. click the "Default" entry, click "browse" to change the default folder.
That did the trick.
Thank you
