NewsPro and VirtualPC
gOOdgUESs
Post by gOOdgUESs »
I'm back again with the same issue (http://www.netwu.com/newspro/phpBB2/vi ... .php?t=840).
Seems it is caused by the icon in the taskbar notification area.
Got the same behavior on another install of XP Pro, and on Windows 2000 and 2003.
Thanx
you mean the icon in the system tray?
you can remove it by unchecking edit menu->icon in the system tray (or maybe you did it and this is how you found out then).
