NewsPro Freezing with Norton Systemworks 2005
Hambone
Post by Hambone »
Just thought people should know that if you install NewsPro after Nortons is already installed you may have lockup/freezing issues while using newspro. The problem was Norton internet worm protection. If you disable the worm protection you will notice that Newspro will work properly again. Just my 2 cents worth after messing with my comp for hours trying to figure it out.
