I've got my newsgroups and subcategories organized such that all data from one group always gets save to the same directory. In the past, I've just used the all filter and set the save. But in too many of these groups, there are postings I don't want to download and save.
I know I can use Alt+K when selecting the posts to download, but is there any way of setting an autosave for a newsgroup, so that just selecting the post will save the attachments off to my hard drive?
Thanks for putting up with a newbie to this discussion forum.
Autosave without Filter
In properties->newsgroups set a destination directory for the newsgroup (browse button) and uncheck the 'ask' check box, then the browse for folder dialog won't appear.
The destination directories for newsgroups (not the default entry on the top) persist and always will be shown as the initial choice in the select dialog.
