download the whole thread
dipo99
Post by dipo99 »
Hello.
Is there a way to download the whole thread in UE?
Newspro can do this by press (crtl+d or crtl+I). In UE it seems not possible.
best regards
Dirk
you can select the thread by dragging the mouse and then press space.
i didn't add the function (if it is added it would be in 'advanced', since i was trying to minimize the main context menu). ue is well aware of threads (threads are implemented somewhat better than in newspro) so it is possible to add, from other side to select a thread and press space is about the same effort as to press a control sequence.
but if other people need it just press me until i add it, after i'll clarify with the usenet indexing (i've started writing code only now, these releases kill my ability to think :) ).
