"Undelete Headers"
Robert2413
"Undelete Headers"
Post by Robert2413 »
In a compact binary newsgroup, I tried to "undelete headers" in the "advanced" context menu, but nothing happened. I then tried checking "Deleted" in Properties/General under "Tracking expired/purged headers." Then I downloaded some more headers, applied "delete headers and replies", and then tried to "undelete headers" again. However, the headers still did not return to the newsgroup view window; again nothing happened.
This is not consistent with the operation of this command in NewsPro, where it worked fine.
you need to check 'del' in the quick filter, then it will show deleted headers (you can also check ^del as well then it will show every header, deleted or not). then you select deleted headers you want to undelete and invoke 'undelete headers'.
Robert2413
Thanks! That did the trick.
