Does UE Support SSL Connections
EdA
Post by EdA »
Title says it all.
Cheers,
Eddie
you need to use stunnel, it is pretty good i think there was a thread about it not so long time ago.
i could add it in principle for about two years was working with ssl source code (not for newsreader).
EdA
Post by EdA »
Yeah. I'm trying stunnel at the moment on my Linux box that sits between Windoze and my cable connection, but it seems very flakey. If I limit UE to a single connection, then it all seems to works OK. But if I try more connections, I get Segmentation Faults. Sometimes immediately, sometimes after a many minutes. I'll investigate more and try asking some questions on the stunnel board.
Cheers,
Eddie
there was another thread regarding ssl
http://www.netwu.com/newspro/phpBB2/vie ... hlight=ssl
it shouldn't crash at all since it is a simple wrap around a very reliable library, you can run it on your windows machine as well, it doesn't eat much resources.
EdA
Post by EdA »
Looks like it's the 4.10 version of stunnel that's the problem. Going back to 4.9 is much more stable.
Cheers,
Eddie
