I have UE set up to automatically get new headers every two hours. I have created a search group to do an extensive search for particular messages, something that takes an hour or so to complete. Every two hours it kicks off a rescan of the search group. I have found no way to get it to not do this. There is no reason to get the headers again because I have already done the search with a "natural" retention and picked the messages that I want to dl.
How can I stop this behavior?
Steven
Autoscan and Search Groups
You can set your global settings by selecting "newsgroups". This setting will be overrided if you set something for a specific group.
Remember you will have to disable automation for groups you don't want to be included if you use the global setting...
If you don't want a rescan at all, leave that setting blank.
