right click - select all messages
elshout
Post by elshout »
Alex,
what a GREAT product ..!! Your previous "baby" fel over at least once a week, this runs AND KEEPS running like clockwork.
What would greatly boots my customer exerience is a button as part of the right click to SELECT ALL messages...maybe even also SELECT AND DELETE ALL... this would speed up and reduce my clicks dramatically, and dont need to use left hand on kayboard anymore.
regards and keep up ..! :D :D
jaapf
Post by jaapf »
Why not use your right hand on your keyboard anymore?
It's the best way not to get RSI...
Just press: [CTRL][A] - [SHIFT][DEL]
right.
besides select and delete all would be very dangerous shortcut.
ctrl+a should work everywhere to select all then a second shortcut to delete (delete shorcuts can be customized, ctrl+a is hardwired into the program, so it is mentioned at the top in UE.txt but not in menus).
mhex
Post by mhex »
you could put a "select all" feature in the "Advanced" sub-menu, just like newspro had, that would be handy, not everyone will know you need to use ^A
the shortcut is stated in UE.txt (help notes) on the very top, help menu->help notes or even on the UE homepage.
UE.txt is a small file, better to read it, it addresses important issues as well which are otherwise are not so obvious.
