UE minimizes window.
THXTEX
Post by THXTEX »
Hi
I use UE on a Windows 2003 Server. I acces it through Terminal Server and have noticed that if i disconnect from the server and connect again, UE is minimized to the tray. Is this normal? All other opened applications are as before i logged off.
you can try uncheck edit menu->inon system tray.
if it happens on restart uncheck edit menu->start minimized.
but with remote desktop you need to wait sometimes until application window is shown, i also have impression it is minimized when you enter remote desktop and only later the application window reappears.
