Request/suggestion :)
hholland
Post by hholland »
Alex;
I sort my newsgroup views by date, most recently received headers on TOP.
UE defaults the scroll bar pointer to the BOTTOM of the view when opened.
Can you give us (ME) an option to default it to the TOP ?
P.s. The Index service works GREAT :)
Hal
Invader
Post by Invader »
Seconded - ( Asked Quite a while back, but you were busy programming with the main program then... )
i made a note here, when i'll have an opportunity i'll check it (i.e. most likely i'll add it in the next version).
ok it will be in the next version (i added it here).
hholland
Post by hholland »
:) Thanks Alex, You are a gentleman :)
Invader
Post by Invader »
Cheers, Thank you..... :wink:
