European languages not supported?
kurt72
Post by kurt72 »
If I look for "ärzte" no results are returned but if I look for "rzte" there are plenty of results which include "ärzte".
it should work but i see it doesn't work, i'm checking it now, something simple.
i think i fixed it, i'm restarting the server now, in 10 minutes it will be up.
kurt72
Post by kurt72 »
Thank YOU for the SUPER FAST FIX, the search now returns correct results for both small and capital letters with umlauts.
