Server maintenance
Server maintenance
I'm currently troubleshooting a problem which started causing rare (several times a day) 20 - 60 sec spikes in processor usage after calling a certain function.
Since I may restart the server and cause the spikes intentionally the server may be inaccessible at times. I'm almost done with locating it and I'll be running the server undisturbed during the peak hours.
ok i got all necessary info and found the reason, using the opportunity i'll make few small changes as well and update the server later.
i fixed everything and updated the server.
